[GRASS-QA] GRASS QA: markus | ./grass6/general/g.parser/main.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Aug 23 07:40:09 EDT 2006
Hello markus,
ANALYSIS
general/g.parser/main.c functions
translate (Begins at: 33 Ends at: 41)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 9 | | OK |
metrics are OK
parse_toplevel (Begins at: 43 Ends at: 72)
Complexity: | 6 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 30 | | OK |
metrics are OK
parse_module (Begins at: 74 Ends at: 104)
Complexity: | 5 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 31 | | OK |
metrics are OK
parse_flag (Begins at: 106 Ends at: 147)
Complexity: | 7 | | OK |
CalledNBR: | 14 | | OK |
LOC: | 42 | | OK |
metrics are OK
parse_type (Begins at: 149 Ends at: 164)
Complexity: | 4 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 16 | | OK |
metrics are OK
parse_boolean (Begins at: 166 Ends at: 178)
Complexity: | 3 | | OK |
LOC: | 13 | | OK |
metrics are OK
parse_option (Begins at: 180 Ends at: 263)
Complexity: | 14 | | OK |
CalledNBR: | 30 | | OK |
LOC: | 84 | | OK |
metrics are OK
main (Begins at: 265 Ends at: 409)
Complexity: | 16 | * | |
CalledNBR: | 38 | * | |
LOC: | 145 | * | |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-08-23 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
