[GRASS-QA] GRASS QA: markus | ./grass6/lib/ogsf/gvl_calc.c |no clones | 0 monsters | 2 warnings
Wed Aug 23 07:40:13 EDT 2006
Hello markus,
ANALYSIS
lib/ogsf/gvl_calc.c functions
iso_w_cndx (Begins at: 64 Ends at: 85)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
iso_r_cndx (Begins at: 89 Ends at: 108)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
iso_get_cube_value (Begins at: 112 Ends at: 147)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       5 |       |      OK |
LOC:          |      36 |       |      OK |
metrics are OK
iso_get_range (Begins at: 151 Ends at: 154)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
iso_get_cube_values (Begins at: 158 Ends at: 169)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
iso_get_cube_grads (Begins at: 173 Ends at: 232)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      18 |       |      OK |
LOC:          |      60 |       |      OK |
metrics are OK
iso_calc_cube (Begins at: 236 Ends at: 439)
Complexity:   |      35 |    ** | Warning |
CalledNBR:    |      46 |     * |         |
LOC:          |     204 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
gvl_isosurf_calc (Begins at: 443 Ends at: 576)
Complexity:   |      16 |     * |         |
CalledNBR:    |      13 |       |      OK |
LOC:          |     134 |     * |         |
metrics are OK
gvl_write_char (Begins at: 579 Ends at: 598)
ParamNBR:     |       3 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
gvl_read_char (Begins at: 601 Ends at: 604)
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
gvl_align_data (Begins at: 607 Ends at: 632)
LOC:          |      26 |       |      OK |
metrics are OK
slice_get_value (Begins at: 634 Ends at: 659)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
slice_calc (Begins at: 662 Ends at: 808)
CalledNBR:    |      21 |       |      OK |
LOC:          |     147 |     * |         |
metrics are OK
gvl_slices_calc (Begins at: 811 Ends at: 843)
LOC:          |      33 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-23 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
