[GRASS-QA] GRASS QA: markus | ./grass6/lib/ogsf/gvl_calc.c |no
clones | 0 monsters | 2 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Aug 23 07:40:13 EDT 2006
Hello markus,
ANALYSIS
lib/ogsf/gvl_calc.c functions
iso_w_cndx (Begins at: 64 Ends at: 85)
Complexity: | 5 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 22 | | OK |
metrics are OK
iso_r_cndx (Begins at: 89 Ends at: 108)
Complexity: | 3 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 20 | | OK |
metrics are OK
iso_get_cube_value (Begins at: 112 Ends at: 147)
Complexity: | 8 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 5 | | OK |
LOC: | 36 | | OK |
metrics are OK
iso_get_range (Begins at: 151 Ends at: 154)
Complexity: | 1 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 4 | | OK |
metrics are OK
iso_get_cube_values (Begins at: 158 Ends at: 169)
Complexity: | 2 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 12 | | OK |
metrics are OK
iso_get_cube_grads (Begins at: 173 Ends at: 232)
Complexity: | 7 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 18 | | OK |
LOC: | 60 | | OK |
metrics are OK
iso_calc_cube (Begins at: 236 Ends at: 439)
Complexity: | 35 | ** | Warning |
CalledNBR: | 46 | * | |
LOC: | 204 | ** | Warning |
at least 2 values are close to an outlier please consider revising code
gvl_isosurf_calc (Begins at: 443 Ends at: 576)
Complexity: | 16 | * | |
CalledNBR: | 13 | | OK |
LOC: | 134 | * | |
metrics are OK
gvl_write_char (Begins at: 579 Ends at: 598)
ParamNBR: | 3 | | OK |
LOC: | 20 | | OK |
metrics are OK
gvl_read_char (Begins at: 601 Ends at: 604)
CalledNBR: | 0 | | OK |
LOC: | 4 | | OK |
metrics are OK
gvl_align_data (Begins at: 607 Ends at: 632)
LOC: | 26 | | OK |
metrics are OK
slice_get_value (Begins at: 634 Ends at: 659)
Complexity: | 4 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 26 | | OK |
metrics are OK
slice_calc (Begins at: 662 Ends at: 808)
CalledNBR: | 21 | | OK |
LOC: | 147 | * | |
metrics are OK
gvl_slices_calc (Begins at: 811 Ends at: 843)
LOC: | 33 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-08-23 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
