[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.net.steiner/main.c
|1 clones ( main.c main.c main.c main.c main.c main.c main.c
main.c parser.c main.c main.c main.c main.c main.c main.c
main.c main.c null.c main.c main.c main.c main.c main.c
main.c main.c main.c main.c )| 3 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Aug 23 07:40:26 EDT 2006
Hello markus,
ANALYSIS
vector/v.net.steiner/main.c functions
init_node_costs (Begins at: 51 Ends at: 74)
Complexity: | 4 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 24 | | OK |
metrics are OK
get_node_costs (Begins at: 80 Ends at: 105)
ParamNBR: | 3 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 26 | | OK |
metrics are OK
mst (Begins at: 107 Ends at: 293)
Complexity: | 19 | * | |
ParamNBR: | 9 | *** | MONSTER |
CalledNBR: | 27 | | OK |
LOC: | 187 | ** | Warning |
1 metric are OUT OF RANGE!
main (Begins at: 295 Ends at: 580)
Complexity: | 20 | * | |
CalledNBR: | 102 | *** | MONSTER |
LOC: | 286 | *** | MONSTER |
2 metric are OUT OF RANGE!
cmp (Begins at: 582 Ends at: 594)
Complexity: | 3 | | OK |
LOC: | 13 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
cmp
In vector/v.net.steiner/main.c clones of cmp are:
vector/v.net.salesman/main.c cmp
Threshold GRASS6 key metrics values at 2006-08-23 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
