[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.net.salesman/main.c |1 clones ( main.c main.c main.c main.c main.c main.c main.c main.c parser.c main.c main.c main.c main.c main.c main.c main.c main.c null.c main.c main.c main.c main.c main.c main.c main.c main.c )| 2 monsters | 0 warnings
Wed Aug 23 07:40:26 EDT 2006
Hello markus,
ANALYSIS
vector/v.net.salesman/main.c functions
cnode (Begins at: 42 Ends at: 42)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       1 |       |      OK |
metrics are OK
add_city (Begins at: 44 Ends at: 65)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
main (Begins at: 68 Ends at: 358)
Complexity:   |      19 |     * |         |
CalledNBR:    |     103 |   *** | MONSTER |
LOC:          |     291 |   *** | MONSTER |
2 metric are OUT OF RANGE!
cmp (Begins at: 360 Ends at: 372)
Complexity:   |       3 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  cmp
In vector/v.net.salesman/main.c clones of  cmp are:
	vector/v.net.steiner/main.c  cmp
Threshold GRASS6 key metrics values at 2006-08-23 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
