[GRASS-QA] GRASS QA: markus |
./grass6/visualization/nviz/src/nviz_init.c |no clones | 1
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Aug 23 07:40:29 EDT 2006
Hello markus,
ANALYSIS
visualization/nviz/src/nviz_init.c functions
parse_command (Begins at: 26 Ends at: 326)
Complexity: | 26 | ** | Warning |
ParamNBR: | 4 | | OK |
CalledNBR: | 65 | ** | Warning |
LOC: | 301 | *** | MONSTER |
1 metric are OUT OF RANGE!
Ngetargs (Begins at: 328 Ends at: 360)
Complexity: | 4 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 23 | | OK |
LOC: | 33 | | OK |
metrics are OK
make_red_yellow_ramp (Begins at: 362 Ends at: 373)
Complexity: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 12 | | OK |
metrics are OK
sort_surfs_mid (Begins at: 380 Ends at: 410)
Complexity: | 3 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 31 | | OK |
metrics are OK
set_default_wirecolors (Begins at: 412 Ends at: 442)
CalledNBR: | 3 | | OK |
LOC: | 31 | | OK |
metrics are OK
Ninit (Begins at: 444 Ends at: 469)
Complexity: | 2 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 26 | | OK |
metrics are OK
Ninitdata (Begins at: 473 Ends at: 494)
CalledNBR: | 6 | | OK |
LOC: | 22 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-08-23 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
