[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.lake/main.c |no clones | 3 monsters | 0 warnings
Wed Aug 23 07:48:25 EDT 2006
Hello markus,
ANALYSIS
raster/r.lake/main.c functions
save_map (Begins at: 41 Ends at: 83)
Complexity:   |       9 |       |      OK |
ParamNBR:     |       9 |   *** | MONSTER |
CalledNBR:    |      14 |       |      OK |
LOC:          |      43 |       |      OK |
1 metric are OUT OF RANGE!
is_near_water (Begins at: 86 Ends at: 103)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
load_window_values (Begins at: 106 Ends at: 138)
ParamNBR:     |       6 |     * |         |
LOC:          |      33 |       |      OK |
metrics are OK
main (Begins at: 140 Ends at: 423)
Complexity:   |      33 |    ** | Warning |
CalledNBR:    |     112 |   *** | MONSTER |
LOC:          |     284 |   *** | MONSTER |
2 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-23 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
