[GRASS-QA] GRASS QA: paul | ./grass6/vector/v.surf.idw/read_sites.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Aug 25 12:00:08 EDT 2006
Hello paul,
ANALYSIS
vector/v.surf.idw/read_sites.c functions
read_sites (Begins at: 16 Ends at: 98)
Complexity: | 13 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 31 | | OK |
LOC: | 83 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-08-25 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
