[GRASS-QA] GRASS QA: markus | ./grass6/vector/lidar/v.outlier/main.c |no clones | 2 monsters | 0 warnings
Tue Aug 29 10:32:03 EDT 2006
Hello markus,
ANALYSIS
vector/lidar/v.outlier/main.c functions
main (Begins at: 37 Ends at: 345)
Complexity:   |      22 |     * |         |
CalledNBR:    |     126 |   *** | MONSTER |
LOC:          |     309 |   *** | MONSTER |
2 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-29 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
