[GRASS-QA] GRASS QA: glynn | ./grass6/lib/driver/Draw.c |1 clones (
main.c command.c Draw.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Aug 30 15:04:09 EDT 2006
Hello glynn,
ANALYSIS
lib/driver/Draw.c functions
DRV_draw_bitmap (Begins at: 4 Ends at: 10)
Complexity: | 2 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 7 | | OK |
metrics are OK
DRV_draw_line (Begins at: 12 Ends at: 16)
LOC: | 5 | | OK |
metrics are OK
DRV_draw_point (Begins at: 18 Ends at: 22)
ParamNBR: | 2 | | OK |
LOC: | 5 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
DRV_draw_bitmap
In lib/driver/Draw.c clones of DRV_draw_bitmap are:
display/drivers/lib/Draw.c DRV_draw_bitmap
Threshold GRASS6 key metrics values at 2006-08-30 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
