[GRASS-QA] GRASS QA: glynn | ./grass6/lib/raster/com_proto.c |2
clones ( main.c command.c Draw.c com_proto.c )| 0 monsters |
0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Aug 30 15:04:09 EDT 2006
Hello glynn,
ANALYSIS
lib/raster/com_proto.c functions
R_screen_left (Begins at: 24 Ends at: 36)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 13 | | OK |
metrics are OK
R_screen_rite (Begins at: 38 Ends at: 50)
LOC: | 13 | | OK |
metrics are OK
R_screen_bot (Begins at: 52 Ends at: 65)
LOC: | 14 | | OK |
metrics are OK
R_screen_top (Begins at: 67 Ends at: 70)
LOC: | 4 | | OK |
metrics are OK
R_get_num_colors (Begins at: 72 Ends at: 88)
LOC: | 17 | | OK |
metrics are OK
R_color_table_float (Begins at: 90 Ends at: 106)
LOC: | 17 | | OK |
metrics are OK
R_color_table_fixed (Begins at: 108 Ends at: 111)
LOC: | 4 | | OK |
metrics are OK
R_color_offset (Begins at: 113 Ends at: 126)
LOC: | 14 | | OK |
metrics are OK
R_color (Begins at: 128 Ends at: 143)
LOC: | 16 | | OK |
metrics are OK
R_standard_color (Begins at: 145 Ends at: 162)
LOC: | 18 | | OK |
metrics are OK
R_RGB_color (Begins at: 164 Ends at: 182)
ParamNBR: | 3 | | OK |
LOC: | 19 | | OK |
metrics are OK
R_reset_color (Begins at: 184 Ends at: 203)
ParamNBR: | 4 | | OK |
LOC: | 20 | | OK |
metrics are OK
R_reset_colors (Begins at: 205 Ends at: 218)
ParamNBR: | 5 | * | |
LOC: | 14 | | OK |
metrics are OK
R_line_width (Begins at: 220 Ends at: 232)
LOC: | 13 | | OK |
metrics are OK
R_erase (Begins at: 234 Ends at: 248)
LOC: | 15 | | OK |
metrics are OK
R_move_abs (Begins at: 250 Ends at: 268)
ParamNBR: | 2 | | OK |
LOC: | 19 | | OK |
metrics are OK
R_move_rel (Begins at: 270 Ends at: 285)
LOC: | 16 | | OK |
metrics are OK
R_cont_abs (Begins at: 287 Ends at: 307)
LOC: | 21 | | OK |
metrics are OK
R_cont_rel (Begins at: 309 Ends at: 325)
LOC: | 17 | | OK |
metrics are OK
R_polydots_abs (Begins at: 327 Ends at: 345)
LOC: | 19 | | OK |
metrics are OK
R_polydots_rel (Begins at: 347 Ends at: 366)
LOC: | 20 | | OK |
metrics are OK
R_polyline_abs (Begins at: 368 Ends at: 388)
LOC: | 21 | | OK |
metrics are OK
R_polyline_rel (Begins at: 390 Ends at: 406)
LOC: | 17 | | OK |
metrics are OK
R_polygon_abs (Begins at: 408 Ends at: 426)
LOC: | 19 | | OK |
metrics are OK
R_polygon_rel (Begins at: 428 Ends at: 445)
LOC: | 18 | | OK |
metrics are OK
R_box_abs (Begins at: 447 Ends at: 463)
LOC: | 17 | | OK |
metrics are OK
R_box_rel (Begins at: 465 Ends at: 478)
LOC: | 14 | | OK |
metrics are OK
R_text_size (Begins at: 480 Ends at: 483)
LOC: | 4 | | OK |
metrics are OK
R_text_rotation (Begins at: 485 Ends at: 501)
LOC: | 17 | | OK |
metrics are OK
R_set_window (Begins at: 503 Ends at: 516)
LOC: | 14 | | OK |
metrics are OK
R_text (Begins at: 518 Ends at: 538)
LOC: | 21 | | OK |
metrics are OK
R_get_text_box (Begins at: 540 Ends at: 575)
LOC: | 36 | | OK |
metrics are OK
R_font (Begins at: 577 Ends at: 580)
LOC: | 4 | | OK |
metrics are OK
R_font_freetype (Begins at: 582 Ends at: 585)
LOC: | 4 | | OK |
metrics are OK
R_charset (Begins at: 587 Ends at: 590)
LOC: | 4 | | OK |
metrics are OK
R_font_freetype_release (Begins at: 592 Ends at: 595)
LOC: | 4 | | OK |
metrics are OK
R_panel_save (Begins at: 597 Ends at: 600)
LOC: | 4 | | OK |
metrics are OK
R_panel_restore (Begins at: 602 Ends at: 605)
LOC: | 4 | | OK |
metrics are OK
R_panel_delete (Begins at: 607 Ends at: 626)
LOC: | 20 | | OK |
metrics are OK
R_set_RGB_color (Begins at: 628 Ends at: 654)
LOC: | 27 | | OK |
metrics are OK
R_RGB_raster (Begins at: 656 Ends at: 692)
ParamNBR: | 6 | * | |
LOC: | 37 | | OK |
metrics are OK
R_raster_char (Begins at: 694 Ends at: 697)
LOC: | 4 | | OK |
metrics are OK
R_raster_int (Begins at: 699 Ends at: 702)
LOC: | 4 | | OK |
metrics are OK
R_bitmap (Begins at: 704 Ends at: 707)
LOC: | 4 | | OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
R_polyline_rel R_polydots_rel
In lib/raster/com_proto.c clones of R_polydots_rel are:
In lib/raster/com_proto.c clones of R_polyline_rel are:
lib/gis/get_row.c G_get_map_row_nomask
Threshold GRASS6 key metrics values at 2006-08-30 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
