[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.topmodel/check_ready.c |no clones | 0 monsters | 3 warnings
Sat Dec 9 13:54:31 EST 2006
Hello jachym,
ANALYSIS
raster/r.topmodel/check_ready.c functions
check_ready (Begins at: 5 Ends at: 39)
Complexity:   |       9 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      35 |       |      OK |
metrics are OK
check_required (Begins at: 43 Ends at: 99)
CalledNBR:    |       7 |       |      OK |
LOC:          |      57 |       |      OK |
metrics are OK
check_names (Begins at: 103 Ends at: 277)
Complexity:   |      32 |    ** | Warning |
CalledNBR:    |      50 |     * |         |
LOC:          |     175 |     * |         |
at least 1 values are close to an outlier please consider revising code
check_io (Begins at: 281 Ends at: 474)
Complexity:   |      34 |    ** | Warning |
CalledNBR:    |      42 |     * |         |
LOC:          |     194 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-09 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
