[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.in.ogr/geom.c |no clones | 0 monsters | 3 warnings
Sat Dec 9 13:54:38 EST 2006
Hello markus,
ANALYSIS
vector/v.in.ogr/geom.c functions
centroid (Begins at: 29 Ends at: 145)
Complexity:   |      11 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      40 |     * |         |
LOC:          |     117 |     * |         |
at least 1 values are close to an outlier please consider revising code
geom (Begins at: 149 Ends at: 312)
Complexity:   |      23 |     * |         |
CalledNBR:    |      63 |    ** | Warning |
LOC:          |     164 |     * |         |
at least 2 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-09 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
