[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.extract/main.c |no clones | 2 monsters | 0 warnings
Sat Dec 9 13:54:38 EST 2006
Hello markus,
ANALYSIS
vector/v.extract/main.c functions
add_cat (Begins at: 36 Ends at: 47)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
main (Begins at: 49 Ends at: 363)
Complexity:   |      36 |   *** | MONSTER |
CalledNBR:    |     123 |   *** | MONSTER |
LOC:          |     315 |   *** | MONSTER |
2 metric are OUT OF RANGE!
scan_cats (Begins at: 366 Ends at: 387)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-09 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
