[GRASS-QA] GRASS QA: martinl | ./grass6/display/d.vect/area.c |no clones | 4 monsters | 0 warnings
Sat Dec 9 13:54:39 EST 2006
Hello martinl,
ANALYSIS
display/d.vect/area.c functions
darea (Begins at: 16 Ends at: 358)
Complexity:   |      49 |   *** | MONSTER |
ParamNBR:     |      13 |   *** | MONSTER |
CalledNBR:    |     100 |   *** | MONSTER |
LOC:          |     343 |   *** | MONSTER |
4 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-09 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
