[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.mkgrid/write_grid.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Dec 9 13:54:39 EST 2006
Hello markus,
ANALYSIS
vector/v.mkgrid/write_grid.c functions
write_grid (Begins at: 7 Ends at: 112)
Complexity: | 4 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 12 | | OK |
LOC: | 106 | | OK |
metrics are OK
write_vect (Begins at: 120 Ends at: 146)
Complexity: | 3 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 4 | | OK |
LOC: | 27 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-12-09 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
