[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.kernel/main.c |no
clones | 3 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Dec 13 11:53:45 EST 2006
Hello markus,
ANALYSIS
vector/v.kernel/main.c functions
L (Begins at: 37 Ends at: 61)
Complexity: | 3 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 12 | | OK |
LOC: | 25 | | OK |
metrics are OK
main (Begins at: 64 Ends at: 401)
Complexity: | 29 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 132 | *** | MONSTER |
LOC: | 338 | *** | MONSTER |
2 metric are OUT OF RANGE!
read_points (Begins at: 405 Ends at: 434)
ParamNBR: | 3 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 30 | | OK |
metrics are OK
compute_all_distances (Begins at: 439 Ends at: 463)
Complexity: | 2 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 25 | | OK |
metrics are OK
compute_all_net_distances (Begins at: 468 Ends at: 535)
Complexity: | 5 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 17 | | OK |
LOC: | 68 | | OK |
metrics are OK
compute_net_distance (Begins at: 539 Ends at: 586)
ParamNBR: | 9 | *** | MONSTER |
CalledNBR: | 10 | | OK |
LOC: | 48 | | OK |
1 metric are OUT OF RANGE!
compute_distance (Begins at: 588 Ends at: 634)
Complexity: | 4 | | OK |
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 8 | | OK |
LOC: | 47 | | OK |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-12-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
