[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.patch/main.c |no clones | 3 monsters | 0 warnings
Wed Dec 13 11:53:45 EST 2006
Hello markus,
ANALYSIS
vector/v.patch/main.c functions
main (Begins at: 44 Ends at: 369)
Complexity:   |      39 |   *** | MONSTER |
CalledNBR:    |     132 |   *** | MONSTER |
LOC:          |     326 |   *** | MONSTER |
3 metric are OUT OF RANGE!
copy_records (Begins at: 372 Ends at: 466)
Complexity:   |      16 |     * |         |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      46 |     * |         |
LOC:          |      95 |       |      OK |
metrics are OK
patch (Begins at: 468 Ends at: 507)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      40 |       |      OK |
metrics are OK
max_cat (Begins at: 509 Ends at: 528)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-13 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
