[GRASS-QA] GRASS QA: markus | ./grass6/lib/gis/paths.c |no clones | 0 monsters | 0 warnings
Wed Dec 13 12:03:53 EST 2006
Hello markus,
ANALYSIS
lib/gis/paths.c functions
G_mkdir (Begins at: 15 Ends at: 31)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
G_is_dirsep (Begins at: 33 Ends at: 48)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
G_convert_dirseps_to_host (Begins at: 50 Ends at: 70)
LOC:          |      21 |       |      OK |
metrics are OK
G_convert_dirseps_from_host (Begins at: 72 Ends at: 82)
LOC:          |      11 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-13 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
