[GRASS-QA] GRASS QA: markus |
./grass6/raster3d/r3.out.vtk/errorHandling.c |no clones | 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Dec 21 09:38:40 EST 2006
Hello markus,
ANALYSIS
raster3d/r3.out.vtk/errorHandling.c functions
fatal_error (Begins at: 35 Ends at: 43)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 9 | | OK |
metrics are OK
CloseInputRasterMap (Begins at: 48 Ends at: 58)
Complexity: | 3 | | OK |
ParamNBR: | 1 | | OK |
LOC: | 11 | | OK |
metrics are OK
close_input_raster3d_map (Begins at: 63 Ends at: 75)
LOC: | 13 | | OK |
metrics are OK
release_input_maps_struct (Begins at: 80 Ends at: 110)
Complexity: | 4 | | OK |
CalledNBR: | 13 | | OK |
LOC: | 31 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-12-21 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
