[GRASS-QA] GRASS QA: markus | ./grass6/raster3d/r3.out.vtk/main.c
|3 clones ( main.c )| 0 monsters | 2 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Dec 21 09:38:40 EST 2006
Hello markus,
ANALYSIS
raster3d/r3.out.vtk/main.c functions
create_input_maps_struct (Begins at: 56 Ends at: 81)
Complexity: | 1 | | OK |
ParamNBR: | 0 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 26 | | OK |
metrics are OK
open_input_map (Begins at: 86 Ends at: 101)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 16 | | OK |
metrics are OK
check_input_maps (Begins at: 107 Ends at: 182)
Complexity: | 14 | | OK |
CalledNBR: | 23 | | OK |
LOC: | 76 | | OK |
metrics are OK
open_write_rgb_maps (Begins at: 188 Ends at: 266)
Complexity: | 19 | * | |
ParamNBR: | 4 | | OK |
CalledNBR: | 20 | | OK |
LOC: | 79 | | OK |
metrics are OK
open_write_vector_maps (Begins at: 271 Ends at: 349)
LOC: | 79 | | OK |
metrics are OK
main (Begins at: 355 Ends at: 557)
Complexity: | 24 | * | |
CalledNBR: | 67 | ** | Warning |
LOC: | 203 | ** | Warning |
at least 2 values are close to an outlier please consider revising code
Clone analysis:
This file has 3 potentially cloned functions:
open_input_map open_write_vector_maps open_write_rgb_maps
In raster3d/r3.out.vtk/main.c clones of open_write_vector_maps are:
raster3d/r3.out.vtk/main.c open_write_rgb_maps
In raster3d/r3.out.vtk/main.c clones of open_write_rgb_maps are:
raster3d/r3.out.vtk/main.c open_write_vector_maps
In raster3d/r3.out.vtk/main.c clones of open_input_map are:
raster/r.to.rast3/main.c open_input_raster_map
Threshold GRASS6 key metrics values at 2006-12-21 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
