[GRASS-QA] GRASS QA: brad | ./grass6/lib/gis/area.c |no clones | 0 monsters | 0 warnings
Fri Dec 22 06:44:36 EST 2006
Hello brad,
ANALYSIS
lib/gis/area.c functions
G_begin_cell_area_calculations (Begins at: 33 Ends at: 75)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
G_area_of_cell_at_row (Begins at: 78 Ends at: 111)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
G_begin_polygon_area_calculations (Begins at: 113 Ends at: 154)
CalledNBR:    |       4 |       |      OK |
LOC:          |      42 |       |      OK |
metrics are OK
G_area_of_polygon (Begins at: 156 Ends at: 166)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-22 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
