[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.in.ascii/gethead.c
|no clones | 0 monsters | 2 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue Jul 4 06:11:15 EDT 2006
Hello brad,
ANALYSIS
raster/r.in.ascii/gethead.c functions
getgrdhead (Begins at: 23 Ends at: 88)
Complexity: | 6 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 20 | | OK |
LOC: | 66 | | OK |
metrics are OK
gethead (Begins at: 90 Ends at: 245)
Complexity: | 29 | ** | Warning |
ParamNBR: | 5 | * | |
CalledNBR: | 56 | ** | Warning |
LOC: | 156 | * | |
at least 2 values are close to an outlier please consider revising code
scan_int (Begins at: 247 Ends at: 260)
Complexity: | 4 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 14 | | OK |
metrics are OK
extract (Begins at: 262 Ends at: 281)
Complexity: | 3 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 7 | | OK |
LOC: | 20 | | OK |
metrics are OK
missing (Begins at: 283 Ends at: 290)
Complexity: | 2 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 8 | | OK |
metrics are OK
error (Begins at: 292 Ends at: 304)
ParamNBR: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 13 | | OK |
metrics are OK
file_scan (Begins at: 308 Ends at: 328)
LOC: | 21 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-07-04 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
