[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.in.ascii/main.c |1
clones ( main.c )| 1 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue Jul 4 06:11:18 EDT 2006
Hello brad,
ANALYSIS
raster/r.in.ascii/main.c functions
main (Begins at: 18 Ends at: 252)
Complexity: | 26 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 99 | *** | MONSTER |
LOC: | 235 | ** | Warning |
1 metric are OUT OF RANGE!
file_cpy (Begins at: 255 Ends at: 283)
Complexity: | 5 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 29 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
file_cpy
In raster/r.in.ascii/main.c clones of file_cpy are:
raster/r.in.arc/main.c file_cpy
Threshold GRASS6 key metrics values at 2006-07-04 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
