[GRASS-QA] GRASS QA: hamish | ./grass6/vector/v.label/main.c |no clones | 2 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Wed Jul 5 05:53:45 EDT 2006
Hello hamish,
ANALYSIS
vector/v.label/main.c functions
main (Begins at: 34 Ends at: 390)
Complexity:   |      37 |   *** | MONSTER |
CalledNBR:    |     121 |   *** | MONSTER |
LOC:          |     357 |   *** | MONSTER |
2 metric are OUT OF RANGE!
print_label (Begins at: 392 Ends at: 414)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      17 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-07-05 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
