[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.buffer/main.c |1
clones ( main.c )| 3 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Wed Jul 5 05:53:46 EDT 2006
Hello markus,
ANALYSIS
vector/v.buffer/main.c functions
input_distance (Begins at: 35 Ends at: 121)
Complexity: | 14 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 16 | | OK |
LOC: | 87 | | OK |
metrics are OK
area_in_buffer (Begins at: 128 Ends at: 207)
Complexity: | 8 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 15 | | OK |
LOC: | 80 | | OK |
metrics are OK
stop (Begins at: 209 Ends at: 217)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 9 | | OK |
metrics are OK
main (Begins at: 220 Ends at: 708)
Complexity: | 56 | *** | MONSTER |
CalledNBR: | 179 | *** | MONSTER |
LOC: | 489 | *** | MONSTER |
3 metric are OUT OF RANGE!
Clone analysis:
This file has 1 potentially cloned functions:
stop
In vector/v.buffer/main.c clones of stop are:
raster/r.carve/vect.c open_new_vect
Threshold GRASS6 key metrics values at 2006-07-05 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
