[GRASS-QA] GRASS QA: hamish | ./grass6/ps/ps.map/symbol.c |no clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Fri Jul 7 06:16:18 EDT 2006
Hello hamish,
ANALYSIS
ps/ps.map/symbol.c functions
draw_chain (Begins at: 15 Ends at: 48)
Complexity:   |       6 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
symbol_draw (Begins at: 51 Ends at: 62)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       7 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
symbol_save (Begins at: 66 Ends at: 144)
Complexity:   |      11 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      29 |       |      OK |
LOC:          |      79 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-07-07 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
