[GRASS-QA] GRASS QA: paul | ./grass6/db/drivers/dbf/dbfexe.c |no clones | 4 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Fri Jul 7 06:27:16 EDT 2006
Hello paul,
ANALYSIS
db/drivers/dbf/dbfexe.c functions
execute (Begins at: 42 Ends at: 297)
Complexity:   |      29 |    ** | Warning |
CalledNBR:    |      50 |     * |         |
LOC:          |     256 |   *** | MONSTER |
1 metric are OUT OF RANGE!
get_col_def (Begins at: 300 Ends at: 324)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       0 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
eval_val (Begins at: 326 Ends at: 384)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      59 |       |      OK |
metrics are OK
set_val (Begins at: 386 Ends at: 435)
Complexity:   |       9 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      50 |       |      OK |
metrics are OK
cmp_row (Begins at: 440 Ends at: 473)
CalledNBR:    |       1 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
sel (Begins at: 477 Ends at: 584)
Complexity:   |      14 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      20 |       |      OK |
LOC:          |     108 |       |      OK |
metrics are OK
eval_node (Begins at: 586 Ends at: 897)
Complexity:   |      72 |   *** | MONSTER |
CalledNBR:    |      17 |       |      OK |
LOC:          |     312 |   *** | MONSTER |
2 metric are OUT OF RANGE!
eval_node_type (Begins at: 899 Ends at: 1034)
Complexity:   |      44 |   *** | MONSTER |
LOC:          |     136 |     * |         |
Clone analysis:
Threshold GRASS6 key metrics values at 2006-07-07 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
