[GRASS-QA] GRASS QA: benjamin | ./grass6/gem/at_exit_funcs.c |no
clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Mon Jul 10 13:19:13 EDT 2006
Hello benjamin,
ANALYSIS
gem/at_exit_funcs.c functions
exit_env (Begins at: 28 Ends at: 48)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 19 | | OK |
LOC: | 21 | | OK |
metrics are OK
exit_tmp (Begins at: 51 Ends at: 89)
Complexity: | 6 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 39 | | OK |
metrics are OK
exit_db (Begins at: 92 Ends at: 185)
Complexity: | 23 | * | |
CalledNBR: | 39 | * | |
LOC: | 94 | | OK |
metrics are OK
exit_msg (Begins at: 188 Ends at: 199)
Complexity: | 4 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 12 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-07-10 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
