[GRASS-QA] GRASS QA: benjamin | ./grass6/gem/actions.c |no clones |
0 monsters | 6 warnings
cvs at proxy.soccerlab.polymtl.ca
Mon Jul 10 13:19:13 EDT 2006
Hello benjamin,
ANALYSIS
gem/actions.c functions
check_extension (Begins at: 27 Ends at: 73)
Complexity: | 6 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 23 | | OK |
LOC: | 47 | | OK |
metrics are OK
unpack_extension (Begins at: 80 Ends at: 174)
Complexity: | 18 | * | |
ParamNBR: | 1 | | OK |
CalledNBR: | 44 | * | |
LOC: | 95 | | OK |
metrics are OK
query_extension (Begins at: 177 Ends at: 207)
Complexity: | 2 | | OK |
ParamNBR: | 8 | ** | Warning |
CalledNBR: | 20 | | OK |
LOC: | 31 | | OK |
at least 1 values are close to an outlier please consider revising code
print_cfg (Begins at: 212 Ends at: 227)
Complexity: | 3 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 16 | | OK |
metrics are OK
source_install (Begins at: 232 Ends at: 385)
Complexity: | 14 | | OK |
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 72 | ** | Warning |
LOC: | 154 | * | |
at least 2 values are close to an outlier please consider revising code
bin_install (Begins at: 391 Ends at: 501)
CalledNBR: | 54 | * | |
LOC: | 111 | * | |
test_install (Begins at: 504 Ends at: 627)
Complexity: | 12 | | OK |
CalledNBR: | 63 | ** | Warning |
LOC: | 124 | * | |
uninstall (Begins at: 634 Ends at: 708)
ParamNBR: | 3 | | OK |
CalledNBR: | 24 | | OK |
LOC: | 75 | | OK |
metrics are OK
source_clean (Begins at: 711 Ends at: 743)
Complexity: | 4 | | OK |
CalledNBR: | 12 | | OK |
LOC: | 33 | | OK |
metrics are OK
restore (Begins at: 749 Ends at: 788)
CalledNBR: | 10 | | OK |
LOC: | 40 | | OK |
metrics are OK
list_extensions (Begins at: 794 Ends at: 818)
CalledNBR: | 13 | | OK |
LOC: | 25 | | OK |
metrics are OK
run_post (Begins at: 825 Ends at: 873)
Complexity: | 11 | | OK |
CalledNBR: | 16 | | OK |
LOC: | 49 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-07-10 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
