[GRASS-QA] GRASS QA: glynn | ./grass6/lib/raster/parse_mon.c |no
	clones | 0 monsters | 0 warnings
    cvs at proxy.soccerlab.polymtl.ca
    Mon Jul 10 22:55:13 EDT 2006
Hello glynn,
ANALYSIS
lib/raster/parse_mon.c functions
R_parse_monitorcap (Begins at: 19 Ends at: 103)
Complexity:   |      18 |     * |         |
CalledNBR:    |      23 |       |      OK |
LOC:          |      85 |       |      OK |
metrics are OK
read_line (Begins at: 107 Ends at: 157)
Complexity:   |       9 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      51 |       |      OK |
metrics are OK
substr (Begins at: 162 Ends at: 185)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
build_path (Begins at: 187 Ends at: 225)
Complexity:   |       6 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      39 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-07-10 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
