[GRASS-QA] GRASS QA: cho | ./grass6/raster/r.to.vect/points.c |no
clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Wed Jul 12 22:37:36 EDT 2006
Hello cho,
ANALYSIS
raster/r.to.vect/points.c functions
extract_points (Begins at: 13 Ends at: 129)
Complexity: | 23 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 39 | * | |
LOC: | 117 | * | |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-07-12 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 40 | 180 | 253 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
