[GRASS-QA] GRASS QA: cho | ./grass6/raster/r.to.vect/areas.c |4
clones ( areas.c )| 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Thu Jul 13 04:05:44 EDT 2006
Hello cho,
ANALYSIS
raster/r.to.vect/areas.c functions
extract_areas (Begins at: 108 Ends at: 154)
Complexity: | 6 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 22 | | OK |
LOC: | 47 | | OK |
metrics are OK
update_list (Begins at: 162 Ends at: 322)
Complexity: | 12 | | OK |
CalledNBR: | 33 | * | |
LOC: | 161 | * | |
metrics are OK
end_vline (Begins at: 327 Ends at: 335)
Complexity: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 9 | | OK |
metrics are OK
end_hline (Begins at: 337 Ends at: 345)
LOC: | 9 | | OK |
metrics are OK
start_vline (Begins at: 350 Ends at: 362)
CalledNBR: | 2 | | OK |
LOC: | 13 | | OK |
metrics are OK
start_hline (Begins at: 364 Ends at: 376)
LOC: | 13 | | OK |
metrics are OK
get_ptr (Begins at: 380 Ends at: 417)
LOC: | 38 | | OK |
metrics are OK
nabors (Begins at: 419 Ends at: 485)
CalledNBR: | 4 | | OK |
LOC: | 67 | | OK |
metrics are OK
read_next (Begins at: 489 Ends at: 498)
LOC: | 10 | | OK |
metrics are OK
alloc_areas_bufs (Begins at: 503 Ends at: 528)
CalledNBR: | 5 | | OK |
LOC: | 26 | | OK |
metrics are OK
equiv_areas (Begins at: 533 Ends at: 600)
ParamNBR: | 2 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 68 | | OK |
metrics are OK
map_area (Begins at: 602 Ends at: 631)
Complexity: | 3 | | OK |
LOC: | 30 | | OK |
metrics are OK
add_to_list (Begins at: 635 Ends at: 668)
Complexity: | 4 | | OK |
LOC: | 34 | | OK |
metrics are OK
assign_area (Begins at: 673 Ends at: 686)
Complexity: | 2 | | OK |
LOC: | 14 | | OK |
metrics are OK
more_areas (Begins at: 690 Ends at: 705)
LOC: | 16 | | OK |
metrics are OK
more_equivs (Begins at: 709 Ends at: 724)
LOC: | 16 | | OK |
metrics are OK
update_width (Begins at: 727 Ends at: 754)
Complexity: | 5 | | OK |
LOC: | 28 | | OK |
metrics are OK
Clone analysis:
This file has 4 potentially cloned functions:
more_equivs more_areas start_hline start_vline
In raster/r.to.vect/areas.c clones of start_vline are:
raster/r.to.vect/areas.c start_hline
In raster/r.to.vect/areas.c clones of more_areas are:
raster/r.to.vect/areas.c more_equivs
In raster/r.to.vect/areas.c clones of more_equivs are:
raster/r.to.vect/areas.c more_areas
In raster/r.to.vect/areas.c clones of start_hline are:
raster/r.to.vect/areas.c start_vline
Threshold GRASS6 key metrics values at 2006-07-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 40 | 180 | 253 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
