[GRASS-QA] GRASS QA: markus | ./grass6/lib/db/dbmi_client/select.c
|no clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Fri Jul 14 12:52:43 EDT 2006
Hello markus,
ANALYSIS
lib/db/dbmi_client/select.c functions
cmp (Begins at: 6 Ends at: 14)
Complexity: | 3 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 9 | | OK |
metrics are OK
cmpcat (Begins at: 16 Ends at: 24)
LOC: | 9 | | OK |
metrics are OK
cmpcatkey (Begins at: 26 Ends at: 46)
LOC: | 21 | | OK |
metrics are OK
db_select_int (Begins at: 48 Ends at: 136)
Complexity: | 12 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 23 | | OK |
LOC: | 89 | | OK |
metrics are OK
db_select_value (Begins at: 138 Ends at: 190)
Complexity: | 6 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 11 | | OK |
LOC: | 53 | | OK |
metrics are OK
db_select_CatValArray (Begins at: 192 Ends at: 306)
Complexity: | 18 | * | |
CalledNBR: | 42 | * | |
LOC: | 115 | * | |
metrics are OK
db_CatValArray_sort (Begins at: 310 Ends at: 313)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 4 | | OK |
metrics are OK
db_CatValArray_get_value (Begins at: 319 Ends at: 329)
Complexity: | 2 | | OK |
ParamNBR: | 3 | | OK |
LOC: | 11 | | OK |
metrics are OK
db_CatValArray_get_value_int (Begins at: 335 Ends at: 345)
LOC: | 11 | | OK |
metrics are OK
db_CatValArray_get_value_double (Begins at: 351 Ends at: 363)
CalledNBR: | 2 | | OK |
LOC: | 13 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-07-14 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
