[GRASS-QA] GRASS QA: markus | ./grass6/lib/init/clean_temp.c |no clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Fri Jul 14 12:52:43 EDT 2006
Hello markus,
ANALYSIS
lib/init/clean_temp.c functions
clean_dir (Begins at: 39 Ends at: 104)
Complexity:   |      16 |     * |         |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      30 |       |      OK |
LOC:          |      66 |       |      OK |
metrics are OK
main (Begins at: 107 Ends at: 158)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      52 |       |      OK |
metrics are OK
find_process (Begins at: 161 Ends at: 169)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-07-14 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
