[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.proj/main.c |no clones | 2 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Sat Jul 15 14:15:43 EDT 2006
Hello markus,
ANALYSIS
raster/r.proj/main.c functions
main (Begins at: 69 Ends at: 435)
Complexity:   |      27 |    ** | Warning |
CalledNBR:    |     132 |   *** | MONSTER |
LOC:          |     367 |   *** | MONSTER |
2 metric are OUT OF RANGE!
make_ipol_list (Begins at: 437 Ends at: 456)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-07-15 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
