[GRASS-QA] GRASS QA: markus |
./grass6/raster/r.param.scale/process.c |no clones | 0
monsters | 1 warnings
cvs at proxy.soccerlab.polymtl.ca
Sat Jul 15 14:34:42 EDT 2006
Hello markus,
ANALYSIS
raster/r.param.scale/process.c functions
process (Begins at: 16 Ends at: 241)
Complexity: | 11 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 38 | * | |
LOC: | 226 | ** | Warning |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-07-15 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
