[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.out.arc/main.c |no clones | 0 monsters | 2 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Sat Jul 15 14:44:42 EDT 2006
Hello markus,
ANALYSIS
raster/r.out.arc/main.c functions
main (Begins at: 24 Ends at: 217)
Complexity:   |      18 |     * |         |
CalledNBR:    |      65 |    ** | Warning |
LOC:          |     194 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2006-07-15 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
