[GRASS-QA] GRASS QA: hamish | ./grass6/ps/ps.map/main.c |no clones
| 3 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue Jul 18 04:52:52 EDT 2006
Hello hamish,
ANALYSIS
ps/ps.map/main.c functions
main (Begins at: 70 Ends at: 729)
Complexity: | 96 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 231 | *** | MONSTER |
LOC: | 660 | *** | MONSTER |
3 metric are OUT OF RANGE!
usage (Begins at: 733 Ends at: 737)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 5 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-07-18 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
