[GRASS-QA] GRASS QA: hamish | ./grass6/ps/ps.map/do_geogrid.c |no clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jul 18 07:23:00 EDT 2006
Hello hamish,
ANALYSIS
ps/ps.map/do_geogrid.c functions
do_geogrid (Begins at: 33 Ends at: 131)
Complexity:   |      11 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      28 |       |      OK |
LOC:          |      99 |       |      OK |
metrics are OK
do_geogrid_numbers (Begins at: 137 Ends at: 251)
Complexity:   |      13 |       |      OK |
CalledNBR:    |      34 |     * |         |
LOC:          |     115 |     * |         |
metrics are OK
init_proj (Begins at: 257 Ends at: 297)
Complexity:   |       3 |       |      OK |
CalledNBR:    |      21 |       |      OK |
LOC:          |      41 |       |      OK |
metrics are OK
get_ll_bounds (Begins at: 303 Ends at: 381)
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      79 |       |      OK |
metrics are OK
check_coords (Begins at: 389 Ends at: 447)
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      10 |       |      OK |
LOC:          |      59 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-07-18 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      80 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
