[GRASS-QA] GRASS QA: cho | ./grass6/raster/r.topmodel/check_ready.c
|no clones | 0 monsters | 3 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue Jul 18 15:51:59 EDT 2006
Hello cho,
ANALYSIS
raster/r.topmodel/check_ready.c functions
check_ready (Begins at: 5 Ends at: 39)
Complexity: | 9 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 35 | | OK |
metrics are OK
check_required (Begins at: 43 Ends at: 99)
CalledNBR: | 7 | | OK |
LOC: | 57 | | OK |
metrics are OK
check_names (Begins at: 103 Ends at: 277)
Complexity: | 32 | ** | Warning |
CalledNBR: | 50 | * | |
LOC: | 175 | * | |
at least 1 values are close to an outlier please consider revising code
check_io (Begins at: 281 Ends at: 474)
Complexity: | 34 | ** | Warning |
CalledNBR: | 42 | * | |
LOC: | 194 | ** | Warning |
at least 2 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-07-18 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
