[GRASS-QA] GRASS QA: cho | ./grass6/raster/r.topmodel/file_io.c |no
clones | 1 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue Jul 18 15:51:59 EDT 2006
Hello cho,
ANALYSIS
raster/r.topmodel/file_io.c functions
get_line (Begins at: 6 Ends at: 20)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 15 | | OK |
metrics are OK
read_inputs (Begins at: 24 Ends at: 189)
Complexity: | 17 | * | |
ParamNBR: | 1 | | OK |
CalledNBR: | 49 | * | |
LOC: | 166 | * | |
metrics are OK
write_outputs (Begins at: 193 Ends at: 413)
Complexity: | 19 | * | |
CalledNBR: | 84 | *** | MONSTER |
LOC: | 221 | ** | Warning |
1 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-07-18 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
