[GRASS-QA] GRASS QA: brad | ./grass6/lib/db/dbmi_client/copy_tab.c
|no clones | 5 monsters | 2 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue Jul 18 21:40:49 EDT 2006
Hello brad,
ANALYSIS
lib/db/dbmi_client/copy_tab.c functions
cmp (Begins at: 6 Ends at: 27)
Complexity: | 3 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 22 | | OK |
metrics are OK
db__copy_table (Begins at: 30 Ends at: 351)
Complexity: | 46 | *** | MONSTER |
ParamNBR: | 11 | *** | MONSTER |
CalledNBR: | 142 | *** | MONSTER |
LOC: | 322 | *** | MONSTER |
4 metric are OUT OF RANGE!
db_copy_table (Begins at: 354 Ends at: 368)
Complexity: | 1 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 1 | | OK |
LOC: | 15 | | OK |
metrics are OK
db_copy_table_where (Begins at: 371 Ends at: 385)
ParamNBR: | 7 | ** | Warning |
LOC: | 15 | | OK |
at least 1 values are close to an outlier please consider revising code
db_copy_table_select (Begins at: 388 Ends at: 406)
LOC: | 19 | | OK |
db_copy_table_by_ints (Begins at: 409 Ends at: 417)
ParamNBR: | 9 | *** | MONSTER |
LOC: | 9 | | OK |
1 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-07-18 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
