[GRASS-QA] GRASS QA: hamish | ./grass6/vector/v.proj/main.c |no clones | 1 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jul 18 23:02:47 EDT 2006
Hello hamish,
ANALYSIS
vector/v.proj/main.c functions
main (Begins at: 15 Ends at: 214)
Complexity:   |      23 |     * |         |
CalledNBR:    |      98 |   *** | MONSTER |
LOC:          |     200 |    ** | Warning |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-07-18 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      80 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
