[GRASS-QA] GRASS QA: markus | ./grass6/lib/db/dbmi_client/copy_tab.c |no clones | 5 monsters | 2 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Wed Jul 19 12:14:47 EDT 2006
Hello markus,
ANALYSIS
lib/db/dbmi_client/copy_tab.c functions
cmp (Begins at: 6 Ends at: 27)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
db__copy_table (Begins at: 30 Ends at: 351)
Complexity:   |      46 |   *** | MONSTER |
ParamNBR:     |      11 |   *** | MONSTER |
CalledNBR:    |     142 |   *** | MONSTER |
LOC:          |     322 |   *** | MONSTER |
4 metric are OUT OF RANGE!
db_copy_table (Begins at: 354 Ends at: 368)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       1 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
db_copy_table_where (Begins at: 371 Ends at: 385)
ParamNBR:     |       7 |    ** | Warning |
LOC:          |      15 |       |      OK |
at least 1 values are close to an outlier please consider revising code
db_copy_table_select (Begins at: 388 Ends at: 406)
LOC:          |      19 |       |      OK |
db_copy_table_by_ints (Begins at: 409 Ends at: 417)
ParamNBR:     |       9 |   *** | MONSTER |
LOC:          |       9 |       |      OK |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-07-19 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      80 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
