[GRASS-QA] GRASS QA: paul | ./grass6/display/d.grid/main.c |no clones | 0 monsters | 1 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Thu Jul 20 05:13:14 EDT 2006
Hello paul,
ANALYSIS
display/d.grid/main.c functions
main (Begins at: 33 Ends at: 202)
Complexity:   |      17 |     * |         |
CalledNBR:    |      67 |    ** | Warning |
LOC:          |     170 |     * |         |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2006-07-20 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      80 |
LOC:                    40 |       180 |     253 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
