[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/gisinit.c |no clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Sat Jul 22 21:43:54 EDT 2006
Hello glynn,
ANALYSIS
lib/gis/gisinit.c functions
G_gisinit (Begins at: 21 Ends at: 52)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      32 |       |      OK |
metrics are OK
G_no_gisinit (Begins at: 54 Ends at: 62)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
G__check_gisinit (Begins at: 64 Ends at: 70)
CalledNBR:    |       4 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
gisinit (Begins at: 72 Ends at: 105)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-07-22 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      80 |
LOC:                    40 |       180 |     253 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
