[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/init_map.c |no clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Sat Jul 22 21:43:54 EDT 2006
Hello glynn,
ANALYSIS
lib/gis/init_map.c functions
G__random_d_initialize_0 (Begins at: 14 Ends at: 51)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      38 |       |      OK |
metrics are OK
G__random_f_initialize_0 (Begins at: 54 Ends at: 83)
LOC:          |      30 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-07-22 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      80 |
LOC:                    40 |       180 |     253 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
