[GRASS-QA] GRASS QA: glynn | ./grass6/lib/raster/rem_proto.c |21 clones ( rem_get.c rem_io.c rem_pad.c rem_proto.c )| 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Thu Jul 27 11:28:21 EDT 2006
Hello glynn,
ANALYSIS
lib/raster/rem_proto.c functions
Clone analysis:
This file has 21 potentially cloned functions:
  REM_get_text_box  REM_cont_abs  REM_reset_color  REM_box_rel  REM_standard_color  REM_cont_rel  REM_polygon_abs  REM_polydots_abs  REM_move_abs  REM_polyline_abs  REM_panel_save  REM_polydots_rel  REM_set_RGB_color  REM_reset_colors  select_font  REM_polygon_rel  REM_polyline_rel  REM_RGB_color  REM_box_abs  REM_set_window  REM_RGB_raster
In lib/raster/rem_proto.c clones of  REM_polydots_rel are:
	lib/raster/protocol.c  R_polydots_rel
In lib/raster/rem_proto.c clones of  REM_cont_rel are:
	lib/raster/protocol.c  R_cont_rel
In lib/raster/rem_proto.c clones of  REM_box_rel are:
	lib/raster/protocol.c  R_box_rel
In lib/raster/rem_proto.c clones of  REM_panel_save are:
	lib/raster/protocol.c  R_panel_save
In lib/raster/rem_proto.c clones of  REM_box_abs are:
	lib/raster/protocol.c  R_box_abs
In lib/raster/rem_proto.c clones of  REM_polydots_abs are:
	lib/raster/rem_proto.c  REM_polygon_abs
	lib/raster/protocol.c  R_polygon_abs
	lib/raster/protocol.c  R_polydots_abs
In lib/raster/rem_proto.c clones of  REM_reset_colors are:
	lib/raster/protocol.c  R_reset_colors
In lib/raster/rem_proto.c clones of  REM_RGB_raster are:
	lib/raster/protocol.c  R_RGB_raster
In lib/raster/rem_proto.c clones of  REM_RGB_color are:
	lib/raster/rem_proto.c  REM_polyline_rel
	lib/raster/protocol.c  R_polyline_rel
	lib/raster/protocol.c  R_RGB_color
In lib/raster/rem_proto.c clones of  select_font are:
	lib/raster/protocol.c  select_font
In lib/raster/rem_proto.c clones of  REM_polygon_abs are:
	lib/raster/rem_proto.c  REM_polydots_abs
In lib/raster/rem_proto.c clones of  REM_get_text_box are:
	lib/raster/protocol.c  R_get_text_box
In lib/raster/rem_proto.c clones of  REM_polyline_abs are:
	lib/raster/protocol.c  R_polyline_abs
In lib/raster/rem_proto.c clones of  REM_polyline_rel are:
	lib/raster/rem_proto.c  REM_RGB_color
In lib/raster/rem_proto.c clones of  REM_set_window are:
	lib/raster/protocol.c  R_set_window
In lib/raster/rem_proto.c clones of  REM_set_RGB_color are:
	lib/raster/protocol.c  R_set_RGB_color
In lib/raster/rem_proto.c clones of  REM_polygon_rel are:
	lib/raster/protocol.c  R_polygon_rel
In lib/raster/rem_proto.c clones of  REM_standard_color are:
	lib/raster/protocol.c  R_standard_color
In lib/raster/rem_proto.c clones of  REM_reset_color are:
In lib/raster/rem_proto.c clones of  REM_cont_abs are:
	lib/raster/protocol.c  R_cont_abs
In lib/raster/rem_proto.c clones of  REM_move_abs are:
	lib/raster/protocol.c  R_move_abs
Threshold GRASS6 key metrics values at 2006-07-27 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    39 |       179 |     249 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
