[GRASS-QA] GRASS QA: glynn | ./grass6/lib/raster/rem_io.c |6 clones
( rem_get.c rem_io.c )| 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Thu Jul 27 11:28:20 EDT 2006
Hello glynn,
ANALYSIS
lib/raster/rem_io.c functions
Clone analysis:
This file has 6 potentially cloned functions:
_get REM_kill_driver sync_driver _get_text_2 _hold_signals _send_char
In lib/raster/rem_io.c clones of _hold_signals are:
lib/raster/io.c _hold_signals
In lib/raster/rem_io.c clones of _get_text_2 are:
lib/raster/io.c _get_text_2
In lib/raster/rem_io.c clones of REM_kill_driver are:
lib/raster/io.c R_kill_driver
In lib/raster/rem_io.c clones of _send_char are:
lib/raster/io.c _send_char
In lib/raster/rem_io.c clones of sync_driver are:
lib/raster/io.c sync_driver
In lib/raster/rem_io.c clones of _get are:
Threshold GRASS6 key metrics values at 2006-07-27 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 39 | 179 | 249 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
